exporting results from Discovery Live
hello,
how can i export the results of live simulation to excel or csv?
i need a results-data of each geometry points.
for example each points as Indicies / xyz-koordinate, result(temperature, stress, etc.) as columns
thank you so much for your helps:)
Hello qz36kuze
Contour plot results cannot be exported in csv or any point data format.
You can create charts and then right click on the chart in the setup tree and export it to a csv file. Also, if you perform a parametric study, you can exports the results of that parametric study in a csv file.
