Not able to install ansys 2020 R2 and 2019 R3
Downloaled ansys 2020R2 and 2019R3 but on clicking run as administrator it shows nothin, no error message occur.
_@peteroznewman I am not able to install ansys 2020 r2 and ansys 2019 r3 for students
_@mmadore
Have you extracted the zip files? Do not try and install from inside the archive.
_@Rob yes i extracted the zip file
@anurag57 Did you disable all antivirus applications? When you right-click -> Run as administrator, do you see any setup process start in the Task Manager?
_@mmadore I already uninstalled antivirus and no setup process start in the task manager while doing run as administrator.
@anurag57 If you open Windows Event Viewer and check The Windows Logs, does it show any errors or information concerning Ansys Setup?
@anurag57 Can you try running a silent install? Open a Windows command prompt using right-click -> run as administrator. CD to the directory where the setup.exe resides, then run this command.
setup.exe -silent
Please note, if installing only 2019R3 you will need to update the license file as discussed in this thread.
https://forum.ansys.com/discussion/19805/how-to-renew-ansys-student-product-license
_
@Geo Karnos
@anurag57 Click on the ">" next to Windows logs and then click on one of the log files.... Application or system or Setup or Security
You should then see messages (Events) in the middle window
@mmadore
cd C:\users\dell\Downloads\ACADEMICSTUDENT_2019R3_WINX64
setup.exe -silent -debug
There is a space between setup.exe and -silent, and before -debug.
_
@Geo Karnos
_@mmadore it asked for permission to run but nothing happens
@anurag57 It is "silent", it will run in the background. Please look to see if it created any C:\Program Files\Ansys Inc\Ansys Student directories, or if the setup.exe is running under the "Details" tab of your Task Manager. The -debug flag creates the %temp%\ans_install_tmp####\debug.txt file, can you please copy the text from that log and share it?
_
@mmadore nothing is on program files and in temp files related to ansys
