Simulate the behavior of a solenoid valve
I want to simulate the behavior of a solenoid valve. What function should I use to see during the simulation (animation) how the plunger moves,how it is attracted and then released by the coil?
It is possible to see this translational movement?
  • nchodenchode Forum Coordinator
    edited January 12
    After you run the simulation(in Maxwell), you can plot the fields.
    Right-click on the field and select animate and follow the onscreen setup.
    you will be able to see the plunger movement with field variation.
    Regards
    Navya
  • Hello Navya,
    Thank you for your support.But how can I get this move in maxwell? (Before simulating the program).
    What conditions should be used, or certain translation areas defined?
    @andrein13
    To check the animation before simulating your model.
    1) Define a variable associated with the plunger motion and set up a parametric for that variable.
    Now right click on the modeler window select View>Animate
    Select plunger>Ok
    On the next screen make sure the parametric setup is selected. click ok to see the animation.
