strange deformation under variable load
Hello, I am creating this geometry (figure 1) with Polyline and then Extrude.
The issue is that when I solve the pressure load (figure2) the deformation is very strange (figure 3) as if it considers some boundary in the points.
Any suggestions ?
Thanks a lot
  • @Panos_Ai, good evening!
    At the beginning: it is necessary to know, where are the supports?
    I think, that your issue can be related to the following situation: to create Polyline, you have created a lot of points:
    And now you applied boundary conditions for all these points.
    It seems like your issue is related to these points.
