Importing joule heating from steady-state electric simulation to steady state thermal simulation.
I'm new to ANSYS mechanical and I'm trying to setup a CHT simulation with Fluent and Mechanical. The solid components of my model undergo joule heating, which I solved using the steady-state electric simulation. I am trying to import this joule heating to a steady-state thermal simulation as a heat generation source. I then plan to connect this with fluent for the CHT problem.
My issue is with importing the joule heating. When I try to import the joule heating I get the following error,
" An error occurred while transferring the load. The addin did not generate any data to import."
What can cause this error?
I have attached some images of my model below.
