Issue with thermal result
in Structures
Good day all,
I am working on thermal analysis of a motor in
order to observe the temperature in the motor as a result of the loses. I modeled the motor in maxwell where i calculated the loses and then exported it to ansys workbench. In mechanical, the temperature result i got was not correct cos there was no variation of temp within the motor as expected. Please, i want to know what i am doing wrong. I attached the image of the result in mechanical
Hi @Emmanuel001 Could it be export setting issue on Maxwell side. Please check this post.
https://forum.ansys.com/discussion/22915/negative-loss-imported-into-steady-state-thermal#latest
Thank you Sir for the quick suggestion. I have gone through the discussions in that link but I am still confused. I don't know how to effect the motion setup and analysis settings so that the problem will be solved as suggested in the link. Any help? I really need a way out from this issue. Thanks
