Unable to get temperature variation as a result of loses
Good day all,
I am working on thermal analysis of a motor in
order to observe the temperature in the motor as a result of the loses. I modeled the motor in maxwell where i calculated the loses and then exported it to ansys workbench. In mechanical, the temperature result i got was not correct cos there was no variation of temp within the motor as expected. Please, i want to know what i am doing wrong. I attached the image of the result in mechanical
  • Hello,
    When you imported the heat generation rate to Steady State thermal, do you see the imported load correctly?
    Also, what 'Convection' conditions are you applying here? Please share these screenshots.
