Problem with HPC 2 way FSI setup in command window
I am following the 19.2 oscillating plate command line tutorial and am trying to load my participants inside of the command window but am getting [Errno 2] no such file or directory. Below shows that I ran the cmd line through the folder and opened the system coupling .bat
When I use the provided load participants command I receive the error. Since I am running from the file where the .scp files are in I do not know how to be more specific on which files I want to load.
Is the mapdl.scp file located in E:\ANSYSMASTERFOLDER\OscPlateCmdLineFluent?
