Import .cdb file from Hypermesh into Workbench interface
Hi everyone,
I have a problem with importing file issue.
I had meshed a model by Hypermesh, exported it in .cdb format.
I also had read a bunch of topics which is similar to this issues, they said that i had to tried'External model' in WB 2019.2 but it did not work out.
So, my questions are: How could i import .cdb file properly into WB interface? And Which steps should i do?
Many thanks.
@mssv20140807
You will have to use External Model to read the model into Mechanical
Example Schematic
You can turn off "create geometry" and see if it helps
For information on what is supported for import, check help doc
Importing Mesh-Based Geometry (ansys.com)
For supported element types check:
External Model Supported Element Types (ansys.com)
You have mentioned that it did not work out. What is the process you are using. What is the error message you are getting?
