Frequency Response and Direct Deformation
When i do the analysis in frequency response and direct deformation they are not same with each other. Every process are identical. Is there something I am missing?
Screenshots are given below. They are both for the same body and they are in the same project file.
  • KaiKai Forum Coordinator Posts: 99
    Hi, why do you expect them to be the same? Directional deformation is a contour plot so the max amplitude may not occur at the same location you selected in frequency response. Can you clarify your question?
