Python and neo4j ANSYS — Ansys Learning Forum
I am a new learner to python and to neo4j and I want to do the connection with Python. I am using neo4j version 3.0.3.
I have written the code in Python file referring a tutorial from python programming tutorial, I have also changed the password, since my password is root:
from neo4j.v1 import GraphDatabase, basic_auth
driver = GraphDatabase.driver("bolt://localhost", auth=basic_auth(user = "neo4j", password = "root"))
session = driver.session()
session.run("CREATE (a:Person {name:'Bob'})")
result = session.run("MATCH (a:Person) RETURN a.name AS name")
for record in result:
print(record["name"])
session.close()
But on running it, I am getting the following errors:
Traceback (most recent call last):
 File "D:/Work/MySQL_neo4j_Importer/dumping_ingredients.py", line 3, in <module>
 File "C:\Python27\lib\site-packages\neo4j\v1\session.py", line 148, in session
  session = Session(self)
 File "C:\Python27\lib\site-packages\neo4j\v1\session.py", line 461, in __init__
  self.connection = connect(driver.host, driver.port, driver.ssl_context, **driver.config)
 File "C:\Python27\lib\site-packages\neo4j\v1\connection.py", line 403, in connect
  s = create_connection((host, port))
 File "C:\Python27\lib\socket.py", line 557, in create_connection
  for res in getaddrinfo(host, port, 0, SOCK_STREAM):
socket.gaierror: [Errno 11004] getaddrinfo failed
