How to perform Stress analysis for helical compression spring using APDL?
AhmedzeidAhmedzeid Member Posts: 12
Hello, this is my first project using ANSYS APDL. I want to automate the stress analysis process for a helical compression spring. I found online that such analysis can be done using Combin14, and Mass21 as the applied load. However, I can't seem to find any tutorial where I get to select the end type of the spring, as well as the wire/coil diameters. Are these parameters actually aren't included in the APDL? if yes, is there a way of me adding them manually?
Ahmed Zeid
