How can I obtain the time it takes to run simulations?
B_RahmanB_Rahman Member Posts: 4
I used to be able to obtain it on the Progress report toggled on the workbench, but now it doesn't make any notes, except when an error has occurred and clears itself eventually. Where can I find a written record of the time it takes for my simulations to run? Specifically ANSYS FLUENT
  • DrAmineDrAmine GermanyPosts: 6,847Forum Coordinator
    Accepted Answer
    You can enable solution Monitoring and monitor that or look at the end of the run into the transcript (*.trn files).
    Alternatively is just to look for parallel timer usage in the Solution cell after the run finished.
