Error at Node 0: floating point exception (CFD HYDROCYCLONE)
bcastillobcastillo Member Posts: 1
edited January 19 in Fluids
Hi!
I am working on a case for hydrocyclone and I have the following error when running the VOF and LES model. Before that, I ran the RSM model transient
Reversed flow on 1176 faces of pressure-outlet 7.
Reversed flow on 2322 faces of pressure-outlet 8.
Stabilizing x-momentum to enhance linear solver robustness.
Stabilizing x-momentum using GMRES to enhance linear solver robustness.
Divergence detected in AMG solver: x-momentum Stabilizing y-momentum to enhance linear solver robustness.
Stabilizing y-momentum using GMRES to enhance linear solver robustness.
Divergence detected in AMG solver: y-momentum Stabilizing z-momentum to enhance linear solver robustness.
Stabilizing z-momentum using GMRES to enhance linear solver robustness.
Divergence detected in AMG solver: z-momentum Stabilizing pressure correction to enhance linear solver robustness.
Stabilizing pressure correction using GMRES to enhance linear solver robustness.
Divergence detected in AMG solver: pressure correction
Error at host: floating point exception
Please help if possible.
