Ansys SPEOS- Create solar light in the UV to near IR range — Ansys Learning Forum
jehanxtjehanxt Member Posts: 4
Question
I’m currently trying to apply a solar ray in the range from 250-1700nm on a surface. Below is a picture that represents the spectrum irradiance of the solar light. (I need this because I’m applying this light on a fluorescent dye material)
Answer
As the “natural light” option in Ansys SPEOS starts from 380nm I used the “surface” source option to create the solar light. I would like to know if the way I did is correct or is there a different way to do this.
Step 1: I got the spectral irradiance data in excel (AM 1.5) and normalized the spectrum as follows. When normalize the values are between 0-100%.
Step 2: I choose the “Radiant flux” option to include the UV and near IR range. Above spectrum was added to the spectrum library. I choose the Lambertian type for a constant intensity.
I would like to confirm is there already a solar simulator in Ansys SPEOS that is in the UV to near IR range? Is the above method I did is correct?
Thank You
