Running APDL in ANSYS in ANSYS 2020R1
hamednikhamednik Member Posts: 10
Hello
I have an APDL script and could easily run it in batch mode in ANSYS V18.2. However, it does not work in version 2020R1. (the script is attached).
In the Windows Command Prompt, I first navigate to the ANSYS Product Directory and then use the below command to run the code but it ends up with some error and stop.
"C:\Program Files\ANSYS Inc\v201\ansys\bin\winx64\ansys201.exe" -b -i Bi_Stable.txt -o file.out'
Meanwhile, if I copy these lines in the APDL Session Editor works perfectly. I wonder if there is any change in running in batch mode in this version.
Hamednik
