Thank you! It opens automatically in SpaceClaim when I click on "Geometry" -> "Edit" in Workbench. Can I change it? I should mention that I am a beginner. Thank you so much!
DM need not be installed separately. It should get installed with default installation. Can you please try reinstalling it.
Also you can continue operations in SpaceClaim instead of DM. SpaceClaim is also very user friendly. You will need to use only Combine tool for boolean operations. I would recommend you to go ahead with SpaceClaim. You would love it.
When you do, please insert some images to show the problem you are having.
Say what version of ANSYS you are using, say what CAD system created the UAV geometry, say what file format you exported from your CAD system, say which ANSYS app you are using: SpaceClaim or DesignModeler.
This is addressed to monicagabriela or anyone else, who can answer my question.
I am interested t know, how did you managed to upload video to the page>
I tried to upload mp4 video ( mp4 being the mot common format for MS Widows)...but the system rejected it with message it doesn't conform to the extensions allowed and then list of extensions was shown, which were (I believe) only a picture formats...
Its there under Create --> Boolean.
Can you please insert image of what you can see under Create option.
Keyur
I cannot find it. Please see the picture attached.
I haven't got any "create" in my toolbar.
This is SpaceClaim.
In this, you can use Combine tool under Design tab.
Keyur
It should give as following.
Once you open Design Modeler, you can import file in the session using File menu in DM.
Keyur
Should Design Modeler be downloaded separately? Thank you!
Keyur
Hi Monica,
Are you using the Free ANSYS Student version or some paid academic/commercial license ?
I'm guessing that the latter would be the case here. It's likely that you have a licensing issue.
In this case, check if you have licenses for ANSYS Design Modeler.
You can try this command in CMD Prompt (change your installation path accordingly)
“C:\Program Files\ANSYS Inc\Shared Files\Licensing\winx64\ansysli_util” -checkout ANS_DM
Note: Copy the entire thing including quote ""
Please capture the screenshot of the output and put it in your post here.
Thank you,
Win
sir I created airfoil with boundary but in meshing I am only getting airfoil! any solution
@sumankumar, please open a New Discussion.
Hello, I want to ask how do I Boolean whole parts of my model
I want to model my uav model
when I select, it only selects the wing and the tail
@firdausghani , please open a New Discussion.
Hello.
December 22,2020
