Transient Thermal
Shivam_11Shivam_11 Member Posts: 2
edited January 22 in Fluid Mechanics
I want to simulate a fdm process where the filament is been extruded at temperature of 270deg. celcius and the bed/base temp is 70deg celcius and the heat interaction are conduction and convection, between the filament and filament and base. I need to plot the result as temperature versus time where the temperature of the filament is decreasing over time.
I need to use the ekill method .
Can anyone help me over this .
The geometry which i am using is also been attached here.
U can also reach me on-:
