Ball moves in U tunnel
bozhengbozheng Member Posts: 8
Dear Sir/Madam,
I use explicit dynamics to simulate the U tunnel. The contact is frictionless, the bottom is fixed, the initial velocity is 3m/s, the end time is 1s, total length is 3m. But the ball could not pass through the curve, can you help to find the problem? Thank you!
Bo
  • akhemkaakhemka Forum Coordinator Posts: 676
    Hi @bozheng ,
    Can you please share a snapshot of the results? Also, can you share snapshots of the setup?
    Ashish Khemka
  • bozhengbozheng Member Posts: 8
    Hello Ashish,
    Thanks for your reply. Please see the followings:
    1. simulation result: the ball could not pass through the curve and return back.
          2.Boudary condition:
    materials are all steel. contact 1&2 are frictionless
    Initial condition: velocity is 1.5 m/s
    fixed support is the bottom
    displacement is the following:
    Analysis settings is the following:
    Thanks you so much for your help.
    Best
    Bo
    Hi @bozheng ,
    Can you try improving the mesh near the bent and then check the result? By the way, you may use a transient analysis as well. We suggest an Explicit analysis for simulating scenarios occurring in a fraction of second.
    Ashish Khemka
    Hello Ashish,
    Thanks for your reply. I will try.
    Best
    Bo
    Hello Ashish,
    Thanks for your suggestion, I finished that simulation. I wonder if ansys has the function that when the ball pass through infrared sensor, infrared sensor can detect the ball? If Yes, how can I simulate it? Thank you.
    Best
    Bo
