i am facing these error in material designer ?
when i am using woven composite in material designer then i am getting these error but when i use UDL composite then i am gettin the last error shown in image.
kindly solve this issue
@om_prakash_sinha
Can you try these 2 suggestions and see if they help:
If meshing fails, try decreasing the mesh width.
Try to deactivate the periodic meshing (if enabled).
Thank you,
Matt
Thank you @mmadore I will try and get back to you
