Error while trying to lunch ls-dyna solver
Hi guys,
Do You have idea why this happens? i guess the problem is in the whitespaces characters.
The scirpt want to execture D:\Nowy_folder\Ansys and take the path D:\Nowy_folder\Ansys Inc not into cosideration.
Do You have any ideas how to solve this? or how to rename ANSYS INC into ANSYS_INC and check if it works?
simply renaming causes error while trying to open launcher.
BR,Marcin
@nariox What are you using for your settings under the File Management tab and Customization/Preferences tabs? Can you open a Windows command prompt and enter the command "set" without quotes and send the full output?
Dear respected friends and professionals of ANSYS,
first of all i would like transfer my warm greeting to all of you,
do you know why this kind of problem happened when i make/do run ls-dyna solver?i tried many times ,but the problem is repeatedly happened,so please help me .thank you for your kindness support.
@Dera16 Can you please share full details of the screens you are accessing and the entries you are using in any of the fields or submission settings? Please also open a Windows command prompt and enter the command "set" without quotes and send the full output.
