Ansys Workbench Solution Problem
sina_khmsina_khm Member Posts: 2
I am using the ANSYS workbench version 17.0. I am trying to analyze the steel rolling mechanism by using the Static Structure module. However, I'm getting an error and a warning during the solution, while all other things are good.
  1. Error: " An unknown error occurred during solution. Check the Solver Output on the Solution Information object for possible causes."
  2. Warning: "Not enough constraints appear to be applied to prevent rigid body motion. This may lead to solution warnings or errors. Check results carefully."
  3. Association Project>Model>Static Structural>Solution
I have no idea what to do about this, so I will be grateful if someone can help me to figure out this problem. I need urgent help!
For your consideration, I have attached a zip file containing the CADpart (CATIA V5), the workbench Project Archive, and the Solution Information text file. I would appreciate your reply in advance.
Sina
