Error: Operation would result in illegal T surface bodies
Panos_AiPanos_Ai Member Posts: 3
Hello, I am trying to create a solid body like in the figure 1.
The problem is that when I try to extrude I end up with this error:
In general I want it to be something like that :
Any help would be useful thanks
  • gnagappgnagapp Posts: 98Forum Coordinator
    @Panos_Ai
    extrude each semi-circular region separately
    That is, extrude the curves highlighted in the image separately. Repeat this for each region
    Once you create separate solids, you can select all the solids in the tree, right click and select "form new part" to connect the bodies using shared topology
    See if this helps
    @Panos_Ai
    Or see if you can create surface from sketch. Then select and extrude 3 faces . Select faces that do not share vertex
    Example
    Repeat this operation for the remaining 3 faces. Then use "form new part"
