How can I fix " C:\Users\david\AppData\Local\Temp\AnsysWBDumpFile.dmp "?
Hello, I've been trying to incorporate a mesh into a elbow pipe in Ansys fluent. I'll create the geometry and generate the shape, but when I click on mesh it says an error occurred and that it's in C:\Users\david\AppData\Local\Temp\AnsysWBDumpFile.dmp . I've read the other forums that solve this issue for other people, but non of them have worked for me. I changed the nvidia to higher graphics, I added the dll's, I tried to redownload it, and I've redone the geometry dozens of times.
Any tips on how to help? I'd really like to figure this out so I don't have to run it through citrix...
  • mmadoremmadore Ansys Employee Posts: 717
    @mcpattydaddy Have you tried renaming your %APPDATA%\Ansys\vXXX directory to vXXX.old where vXXX is the version you're running? Does this only happen with that one project?
  • mcpattydaddymcpattydaddy Member Posts: 4
    I did try that, and it still popped up with the same error. I've also tried different projects and the same message pops up, some in fluent and others in static structural.
    I have the dump file copied to my desktop, it won't allow me to place it here. It's encrypted, but I can send it to someone on the support team to see what it says and maybe that will provide an answer to why it's giving me such problems.
    Please open a Windows command prompt and run the command "set" and return the full output.
    C:\Users\david>set
    ADSK_CLM_WPAD_PROXY_CHECK=FALSE
    ALLUSERSPROFILE=C:\ProgramData
    ANSYS211_DIR=C:\Users\david\Desktop\ANSYS\ANSYS Inc\ANSYS Student\v211\ANSYS
    ANSYS_SYSDIR=winx64
    APPDATA=C:\Users\david\AppData\Roaming
    AWP_LOCALE211=en-us
    AWP_ROOT211=C:\Users\david\Desktop\ANSYS\ANSYS Inc\ANSYS Student\v211
    CADOE_LIBDIR211=C:\Users\david\Desktop\ANSYS\ANSYS Inc\ANSYS Student\v211\CommonFiles\Language\en-us
    CommonProgramFiles=C:\Program Files\Common Files
    CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
    CommonProgramW6432=C:\Program Files\Common Files
    COMPUTERNAME=DESKTOP-LRHAV4F
    ComSpec=C:\WINDOWS\system32\cmd.exe
    DriverData=C:\Windows\System32\Drivers\DriverData
    HOMEDRIVE=C:
    HOMEPATH=\Users\david
    LOCALAPPDATA=C:\Users\david\AppData\Local
    LOGONSERVER=\\DESKTOP-LRHAV4F
    LSTC_LICENSE=ANSYS
    NUMBER_OF_PROCESSORS=8
    OMP_NUM_THREADS=8
    OneDrive=C:\Users\david\OneDrive
    OneDriveConsumer=C:\Users\david\OneDrive
    OS=Windows_NT
    Path=C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\iCLS\;C:\Program Files\Intel\Intel(R) Management Engine Components\iCLS\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;%SYSTEMROOT%\System32\OpenSSH\;C:\Program Files\MATLAB\bin;C:\Users\david\AppData\Local\Microsoft\WindowsApps;
    PROCESSOR_ARCHITECTURE=AMD64
    PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 158 Stepping 9, GenuineIntel
    PROCESSOR_LEVEL=6
    PROCESSOR_REVISION=9e09
    ProgramData=C:\ProgramData
    PROMPT=$P$G
    PSModulePath=C:\Program Files\WindowsPowerShell\Modules;C:\WINDOWS\system32\WindowsPowerShell\v1.0\Modules
    PUBLIC=C:\Users\Public
    SESSIONNAME=Console
    SystemDrive=C:
    SystemRoot=C:\WINDOWS
    TEMP=C:\Users\david\AppData\Local\Temp
    TMP=C:\Users\david\AppData\Local\Temp
    USERDOMAIN=DESKTOP-LRHAV4F
    USERDOMAIN_ROAMINGPROFILE=DESKTOP-LRHAV4F
    USERNAME=david
    USERPROFILE=C:\Users\david
    windir=C:\WINDOWS
    Please run dxdiag from a Windows command prompt and send the full output.
