Validate conservation of momentum in Fluent
Dears, hope you are doing fantastic
I am working on a model (mixing elbow heat transfer - 3D) problem using Fluent.
I was wondering how to validate or represent (conservation of momentum) principle using Fluent, I know that for mass and energy we can do it using flux report. But what is the property that checks momentum for such cases.
Thank you all.
Flow Rate of Velocity.
You can calculate forces on the walls ... momentum and pressures at inlet/exit
