icemcfd will not launch
Creating a new discussion as I have not had a resolution on an earlier issue. Also editing to add that we have tried this with a newer version of Ansys (2020 R1) with similar result so it appears to be system related.
I am using icemcfd with Ansys 19.3. When I launch icemcfd it is very slow to load, sometimes taking up to 3-5 minutes.
The OS is CentOS 7.
I am using environment modules to load the software. This is the environment module.
set topdir /home/ansys2019r3/
set version v195
prepend-path PATH $topdir/$version/ansys/bin
prepend-path PATH $topdir/$version/Framework/bin/Linux64
prepend-path LD_LIBRARY_PATH $topdir/$version/Framework/bin/Linux64/Mesa
prepend-path PATH $topdir/shared_files/licensing/lic_admin
prepend-path PATH $topdir/$version/home/ansys2019r3/v195/fluent/bin
setenv ANSYS182_DIR $topdir/$version/ansys
setenv ANSYSLIC_DIR $topdir/shared_files/licensing
prepend-path PATH $topdir/$version/fluent/bin
prepend-path PATH $topdir/$version/icemcfd/linux64_amd/bin
setenv ICE_ACN $topdir/$version/icemcfd/linux64_amd
prepend-path PATH $topdir/$version/autodyn/bin
prepend-path PATH $topdir/$version/polyflow/bin
Once I type in 'icemcfd' it hangs on ICEM_ACN is "/home/ansys2019r3/v195/icemcfd/linux64_amd" and eventually after 5 minutes the software will launch.
Eventually when it does load I get this output on the command line:
LD_LIBRARY_PATH is "/home/ansys2019r3/v195/icemcfd/linux64_amd/lib
home/ansys2019r3//v195/Framework/bin/Linux64/Mesa
home/ansys2019r3/v195/icemcfd/linux64_amd/bin
home/ansys2019r3/v195/icemcfd/linux64_amd/dif/iges
home/ansys2019r3/v195/icemcfd/linux64_amd/../../Framework/bin/Linux64
home/ansys2019r3/v195/icemcfd/linux64_amd/../../tp/IntelCompiler/2017.6.256/linx64/lib/intel64".
args =
Window information: depth = 24
class = 4
visual depth = 32 class = 4
can't load font screen14, using variable
can't load font symbol14, using variable
can't load font symbol18, using variable
can't load font symbol24, using variable
Graphics system = OglDL
med>
I am not sure what else to troubleshoot. This is a clean installation. I also have the same issue with an existing install on another CentOS 7 machine. Same version of Ansys.
I have tried it without the environment module and I get the same result.
Thanks for any assistance.
@rga20 Could you try without specifying your own LD_LIBRARY_PATH? What is the latency with the license server? Do other applications launch in this environment without issue? This could be graphics related, could you share the results of these commands?
glxinfo -display :0 | grep -i opengl.version
export LIBGL_DEBUG=verbose glxgears
export LIBGL_DEBUG=verbose glxinfo
lspci -vnn | grep VGA -A 12
nvidia-smi
nvidia-settings -q NvidiaDriverVersion
nvidia-settings -q all
Matt
@mmadore
Thanks for the reply.
Tried without specifying our own LD_LIBRARY_PATH, no change. No issues with the license server. Other applications can launch in this environment without any problems. Right now it seems to just be ICEM-CFD.
This just seems to be domain accounts only that this is affecting as well. This Linux server is joined to a Windows AD domain. Icem-cfd opens just fine for root and also for a local account. I used 'env' to compare the environment variables between my account and a local account as a test, there is no considerable difference.
In playing around with the icemcfd launch script, default location: /ansys_inc/v195/icemcfd/linux64_amd/bin I commented out the following lines:
# (re)set limits for at least OSF1 and AIX41
#if (`id | sed 's/^[^=]*=//;s/[( ].*$//'` == 0) then
# root must not unset the limits on
# various operating systems
# echo 'Hallo root.'
#else
# set uname_r=`uname -r`
# set uname_s=`uname -s`
# if ( $uname_s != "Linux" && `expr $uname_r : "B.11*"` < 4) then
# unlimit
# endif
#endif
And this seems to have resolved the problem for my domain account and one other. One other person is still having issues however, I need to do some further troubleshooting with that person, but I do not know why that would make a difference but it has cut the time to open the program down to ~5 seconds from 5 minutes.
This is the output for the commands suggested:
glxinfo | grep -i opengl.version
OpenGL version string: 2.1 Mesa 18.3.4
0a:03.0 VGA compatible controller [0300]: Matrox Electronics Systems Ltd. MGA G200eW WPCM450 [102b:0532] (rev 0a) (prog-if 00 [VGA controller])
Subsystem: Dell Device [1028:0444]
Flags: bus master, medium devsel, latency 64, IRQ 20, NUMA node 0
Memory at e5800000 (32-bit, prefetchable) [size=8M]
Memory at eeffc000 (32-bit, non-prefetchable) [size=16K]
Memory at ee000000 (32-bit, non-prefetchable) [size=8M]
[virtual] Expansion ROM at ee800000 [disabled] [size=64K]
Capabilities: <access denied>
Kernel driver in use: mgag200
Kernel modules: mgag200
20:00.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD/ATI] RD890 Northbridge only dual slot (2x8) PCI-e GFX Hydra part [1002:5a12] (rev 02)
There is no video card in the system. Would appreciate any ideas. Thank you,
@rga20 This machine lacks a supported graphics device and is not supported for running the UI of our applications. While you may see it work, it's unsupported.
