Divergent results between laminar model and blasius result (Asymptotic)
Hello
I am working about fluid flow over flat plate Re: 10E5.
The longitudinal velocity exceeds the inlet velocity
I tried another meshing but the same result.
After, I used different VISCOUS MODEL in the FLUENT. The result shows that the RSM is more adapted than laminar model to Blasius result. Despite the RSM treats the turbulent model.
Couple of things:
I hope this helps.
Typing error : Re=1E5.
For my mesh :
You will need a much better resolution on your mesh, especially near the wall of the flat plate. I'd strongly urge you to have a look at the mesh file from the simulation example I shared with you. This is from our AICs. This would help you get a good understanding of what you need to do.
Thanks.
Thank you
I will come back to you
