ROM Viewer
In the ANSYS Academic version 2020R1, a tab was created 'ROM Viewer' on the Workbench page after 'creating ROM'. But in the R2 version, I couldn't manage to find the ROM Viewer tab.
I had attended a webinar where they have specifically mentioned about the imporvements incorporated in the ROM Viewer in the R2 version, but I don't know how to access ROM Viewer in the R2 version.
Please help. Thanks in advance.
Amitej.
Hello @Amitej
Are you using student version?
Please check out what is included in student version at
Keyur
Hello Keyur.
Yes I have been using the Student version all along. 2020R1 earlier and now 2020R2. 3D ROM is included under the Design Exploration tab in the toolbox on the Workbench page.
Please check Whats Included section in
Keyur
ROM is an snapshot of your designpoints so that it allows users to use as an component in the System design, the possible way to look into ROM is either export to FMU and check the standard here
you can use MATLAB, to open FMU files, that said, this file formt will not help you to visulise the countor of your criteria, rather return an numerical value.
The second approach is use Response surface, It has sliders to interact witht the surface you have created( an chruned down version of FMU). If your aim is to visulise the 3D with all contours, please contact your nearest ANSYS Authorised Reseller or your IT Team, They might help you to setup the all requriements
Cheers,
Ram
