How do we obtain Elastic Served ID?
Hi Everyone,
I installed a free student version of ANSYS on my Mac after performing the Bootcamp procedure and installing windows 10.
After installation of ANSYS, when I tried to run the software, it is asking for "Elastic Server ID"
Does anyone have any idea about how to get that ID or did anyone else have solved this problem?
Kind Regards
mmadore Ansys Employee Posts: 717
@ajmeetdhillon You do not need to do anything in the Client Licensing Settings as the STUDENT applications do not require it. The applications have the licensing built in. You have installed Ansys Discovery Student, which does not include Workbench. Please try installing ANSYS Student.
@ajmeetdhillon Please share a screenshot. You do not have any need for an elastic server id with the Student package. Please also try removing the environment variable ANSYSLI_ELASTIC=1 if it is set.
@mmadore, Please see the attached jpeg file for ElasticServer ID error. After I installed the software, I couldn't see the WORKBENCH app. The only app I could work on was LIC. I couldn't get past this step so couldn't remove the environment variable. The software that I downloaded was "Ansys Discovery Student" from
Looking forward to your response. Have been stuck here for a few days.
@mmadore That Works. Thanks a lot for your help. Appreciate it😀
