Error by meshing SOLID 272
Hello everyone,
I am trying to simulate a compression test on a cylinder. i have created the model, selected element type solid272 : Axisymm 4 nodes 272
Now when i try to mesh, it shows the following error:
"Element type 1 is SOLID 272 , which cannot be used with the VMES command. Meshing of volume 1 is aborted."
I tried the same with SOLID 273 but i still get the same error. I am using ANSYS CLASSIC.
Can anybody please help...
Thanks in advance
Hi @Chihi ,
You are trying to mesh the volume with plane elements. Try using brick or tetrahedral elements.
Ashish Khemka
