Using 1 iteration per substep may result in unconverged solutions for nonlinear analysis and the
i was doing concrete analysis and go this error
 nonlinear analysis and the program may not indicate divergence in this
 case. Check your results.
  • peteroznewmanpeteroznewman Member Posts: 11,071
    @om_prakash_sinha
    Are you working in Mechanical?
    Under Analysis Settings, turn on Auto Time Stepping.
    Turn on Large Deflection.
    That should allow more that 1 iteration per substep, which is normal. You must have changed it to go away from that setting.
  • om_prakash_sinhaom_prakash_sinha Member Posts: 8
    sir i was working on solid 65 so i think i should not turn on large deflection.
    another error are now coming too
    1. Element 3280 using isotropic material 111 has a value of Poisson's ratio of 6.6 which must be greater than -1.0 and less than 0.5.
     for this node is based on extrapolation from element 51.
    1. Node 3068 does not lie on the selected elements. The CEINTF operation for this node is based on extrapolation from element 51.
