How to access solution data from a user material subroutine (UserMat or UserMatTh)? — Ansys Learning Forum
Volker_SlowikVolker_Slowik Member Posts: 2
I am using the user routines UserMat and UserMAtTh for material modelling. Out of the routine, I want to access user state variables for an element other than the current one (other than the one the user routine has been called for). I expected that this can be done by the provided subroutine (API) get_ElmData (kchar, elemId, kMatRecPt, ncomp, vect). However, this subroutine seems to work only for the current element, not for other elements. The element number elemId specified as input for the subroutine is ignored. The output contains always data for the integration points of the current element. Does someone have an idea how to access user state variables of other elements?
  • DavidWDavidW Evanston, ILForum Coordinator Posts: 66
    Accepted Answer
    Hi @Volker_Slowik,
    I spoke to one of our developers and they indicated that there are no routines to get data from other elements from inside a UPF. This capability is not supported but some customers have implemented methods to do it (one potential route would be storing and retrieving data from external files, but note that doing so is not a standard or supported feature of ANSYS software).
    Accepted Answer
    Hi @Volker_Slowik,
  • Volker_SlowikVolker_Slowik Member Posts: 2
    Thank you for responding to my question. Very clear answer.
