One or more entities failed to mesh
Hello all,
I am trying to mesh to import bodies by default but an error appears that says: "one or more entities failed to mesh". Does anyone know how to solve this problem?
Thank you
  • 1shan1shan Ansys Employee Posts: 110
    Hello @michutorres,
    You may try to reduce the element size below the minimum feature size of your geometry. Also turn capture curvature & capture proximity to "YES"(click on mesh and you would find those options under sizing).
    Ishan
  • michutorresmichutorres Member Posts: 2
    Thank you for your help. It was very useful!
    I have another question: when introducing the properties of a fluid in Ansys Fluent, what is the Pure Solvent Melting Heat (j/kg) ?
    Thank you
