Error when starting ANSLIC_ADMIN as adminstrator to specify license server.
Please see attached image for error upon trying to start up ANSLIC_ADMIN to change the license server. Any thoughts on how to resolve this? workbench won't open up since the license server is not specified (connected to VPN). Computer was restarted.
@athoeny Could you please open a Windows command prompt and send the full output of the "set" command? This error typically indicates a problem with some environment variable.
@mmadore Please see attached text document
This is possibly due to the PATH variable. Can you please save the current value in a text pad for backup and then modify the current PATH variable to have only these entries?
C:\WINDOWS\system32;C:\WINDOWS;C: \WINDOWS\System32\Wbem;C: \WINDOWS\System32\WindowsPowerShell\v1.0\;C: \WINDOWS\System32\OpenSSH\
For guidance on creating an Environment Variable please refer to this link. Instead of NEW you want to select the PATH System variable and Edit.
https://www.onmsft.com/how-to/how-to-set-an-environment-variable-in-windows-10
@mmadore
Modified as requested and reinstalled ANSYS to no avail. Here is the current variables from terminal output of the "set" command:
C:\Users\overlord>set
ALLUSERSPROFILE=C:\ProgramData
ANSYS202_DIR=C:\Program Files\ANSYS Inc\v202\ANSYS
ANSYSLIC_DIR=C:\Program Files\ANSYS Inc\Shared Files\Licensing
ANSYS_SYSDIR=winx64
APPDATA=C:\Users\overlord\AppData\Roaming
AWP_LOCALE202=en-us
AWP_ROOT202=C:\Program Files\ANSYS Inc\v202
CADOE_LIBDIR202=C:\Program Files\ANSYS Inc\v202\CommonFiles\Language\en-us
CommonProgramFiles=C:\Program Files\Common Files
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
CommonProgramW6432=C:\Program Files\Common Files
COMPUTERNAME=OVERLORD-PC
ComSpec=C:\WINDOWS\system32\cmd.exe
DriverData=C:\Windows\System32\Drivers\DriverData
HOMEDRIVE=C:
HOMEPATH=\Users\overlord
ICEMCFD_ROOT202=C:\Program Files\ANSYS Inc\v202\icemcfd
ICEMCFD_SYSDIR=win64_amd
ICFD_HOME91=C:\Program Files\METACOMP\mlib\micfd.19.1
ICMP_HOME81=C:\Program Files\METACOMP\mlib\micmp.8.1
ICMP_HOME91=C:\Program Files\METACOMP\mlib\micmp.9.1
IMIME_HOME81=C:\Program Files\METACOMP\mlib\imime.8.1
LOCALAPPDATA=C:\Users\overlord\AppData\Local
LOGONSERVER=\\OVERLORD-PC
LSTC_LICENSE=ANSYS
MCFD_HOME=C:\Program Files\METACOMP\mlib\mcfd.19.1
MCFD_HTML=C:\Program Files\METACOMP\mlib\mcfd.19.1\html
MCFD_MAXMEM=16G
MCFD_PROCMEM=8G
MCFD_TCLTK=C:\Program Files\Metacomp\mlib\mcfd.19.1\exec\gui_src
MCFD_TOGL=yes
MCFD_VERSION=19.1
METACOMP_HOME=C:\Program Files\METACOMP
[email protected];
NUMBER_OF_PROCESSORS=32
OneDrive=C:\Users\overlord\OneDrive - Naval Postgraduate School
OneDriveCommercial=C:\Users\overlord\OneDrive - Naval Postgraduate School
OS=Windows_NT
Path=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\METACOMP\mbin;C:\Program Files\METACOMP\mlib\mcfd.19.1\exec;C:\Program Files\MPICH2\bin;C:\WINDOWS\system32;C:\WINDOWS;C: \WINDOWS\System32\Wbem;C: \WINDOWS\System32\WindowsPowerShell\v1.0\;C: \WINDOWS\System32\OpenSSH\;
PROCESSOR_ARCHITECTURE=AMD64
PROCESSOR_IDENTIFIER=AMD64 Family 21 Model 2 Stepping 0, AuthenticAMD
PROCESSOR_LEVEL=21
PROCESSOR_REVISION=0200
ProgramData=C:\ProgramData
PROMPT=$P$G
PSModulePath=C:\Program Files\WindowsPowerShell\Modules;C:\WINDOWS\system32\WindowsPowerShell\v1.0\Modules
PUBLIC=C:\Users\Public
P_SCHEMA=C:\Program Files\ANSYS Inc\v202\AISOL\CADIntegration\Parasolid\PSchema
SESSIONNAME=Console
SystemDrive=C:
SystemRoot=C:\WINDOWS
TCL_LIBRARY=C:\Program Files\METACOMP\mlib\tcltk8\lib\tcl8.4
TEMP=C:\Users\overlord\AppData\Local\Temp
TK_LIBRARY=C:\Program Files\METACOMP\mlib\tcltk8\lib\tk8.4
TMP=C:\Users\overlord\AppData\Local\Temp
USERDOMAIN=overlord-PC
USERDOMAIN_ROAMINGPROFILE=overlord-PC
USERNAME=overlord
USERPROFILE=C:\Users\overlord
VISITLOC=C:\Users\overlord\LLNL\VisIt 3.1.3
windir=C:\WINDOWS
@athoeny Can you try specifying your license server with environment variables to see if that gets you up and running? This is an example:
[email protected]
[email protected]
Just modify the "server" and port if needed.
