Mesh incompatible error when changing geometry parameter in Fluent
I'm trying to do a parametric study using Fluent. I imported my Solidworks model to Spaceclaim and used the pull function to set up some geometry parameters. My original model works fine and has reasonable results. However, when I try to change the geometry parameters in the parameter set and update the design point, it has an error of 'Model information is incompatible with incoming mesh. Fluent failed to apply some mesh operations'. I noticed that in Fluent whenever there is a change in Mesh, it's pretty easy to get this warning. Is there a way to change geometry parameters without facing this kind of error?
Thanks for your help!
Rob UKForum Coordinator Posts: 8,371
It shouldn't matter as there are no settings assigned to those walls. Using a conformal mesh will remove the problem. In the current set up try File - Batch Options
And "Hide Questions". I've not used that option recently but it may bypass the check to some extent.
It means a surface ID has changed. If the mesh is conformal it's fairly uncommon. If the mesh has interface zones the automatic wall creation can return different IDs each time.
Thanks for your help, Rob. Yes, I'm getting different IDs for the walls. For example, previously I have wall-17, wall-18, for the new model I have wall-12 and wall-13. Is there a way to solve this issue?
I'm not able to find Batch Options in my file menu, I've attached a screenshot below.
In that case Workbench must take care of that.
