Multizone mesh problem with shared topology
I am trying to mesh a pipe assembly.
When not applied shared topology multizone meshing is successfull
But to avoid non conformal meshing i want to use shared topology
But after applying shared topology in spaceclaim the following error encountered.
If i try to mesh one part only the following error message is encountered
This kind of deformed mesh is generated
I am using the following mesh setting
Request help to sort out the problem.
Hello @Ayan,
Try setting mesh based defeaturing to on and set a tolerance greater than the minimum edge size. You my also try inserting local edge sizing control. I would suggest you remove the small steps in your model using spaceclaim. They are trivial and removing them will make it easier to get a good mesh.
Also check out this post https://forum.ansys.com/discussion/15671/multizone-blocking-decomposition-error
Ishan.
