Distorted IGES geometry
I am not sure if this is the most suited forum to open this discussion under. However, I created a simple spring geometry in solidworks and saved it as an .igs file, when I try to import that file in Ansys Mechanical APDL, I end up with this distorted ugly geometry where the volume creation fails. Any pointers on how to avoid such problem?
(Attached are the 3D model and screenshot of distorted geometry)
@Ahmedzeid
Don't use IGES to move solid geometry. Use Parasolid.
@peteroznewman
Thank you for the answer, I can now mesh my geometry and solve my system correctly (See attached mesh). However, my volume plot still doesn't look correct, which causes my code to crash whenever I try to export a screen capture of that plot. Any idea about how I might solve such problem?
Hi Peter,
I have a similar problem because I want to export the IGES file from Mimics software to Workbench but it's not possible. What do you suggest?
Amin
@Ahmedzeid Try Mechanical instead of APDL.
@Amin1372 What file formats does Mimics support?
Hi @Amin1372 , It seems, that Mimics can output .*stl file, if so you can use the Spaceclaim and clean the geomentry and maybe you should try patch independent method( Cartiesian mesh) to analyse the parts.
Cheers,
Ram
@peteroznewman I am afraid that's not an option in my case. Isn't there any solution for the parasolid format in APDL? Or a probable cause even that I can look into?
@Ahmedzeid
I expect APDL can open a Parasolid file. Check the Help file. I don't use APDL interface.
