Error :Note: zone-surface: cannot create surface from sliding interface zone.
bxddstlbxddstl Member Posts: 10
Professor, ,I am a novice. I am doing a simulation of balloon of antifreeze getting impact of crude tank.
I create four component :(tank, crude inside the tank,balloon inside the crude,and antifreeze inside the balloon).
I used transient structure and fluid fluent and system coupling.
But the result is not good: when I see the result of transient structure ,I can see the inflating of balloon animate,no error.
 But when I see the result of fluent fluid result ,the error happen ,when I want to create the contour map though the balloon
   ,it told me(Note: zone-surface: cannot create surface from sliding interface zone.Creating empty surface.)
   when I create contour map that not though the balloon ,no error.
BY the way , selected the dynamic mesh(just select ,I choose no other options)
So I want to ask what happen to the result ,how to fix that.
 thank you for your help.?
