The purpose of the option is to allow the parcels to disperse due to turbulence. If you have a large number of parcels from the injection then fewer tries may be needed, if you have few parcels from the injection then you need more tries. There is also an upper limit on the number of tries based on your hardware. Somewhere between 1 and 1000 is fairly common, 10-100 may be a good starting point.
In which case keep increasing the number of tries until whatever you're monitoring stops changing or the computer falls over. Save before plotting particle trajectories! My earlier comment about 10-100 tries being a good starting point stands.
The particles will follow the flow to varying levels depending on diameter and relative material density. The result looks like what I'd expect to see from a DPM track, whether they're correct is for you to judge based on the flow.
i have 200 number of streams and my droplets have constant diameter of 20 micron.Which number of tries is good for it?
How big is the domain, are particles passing through or are you seeing incomplete tracks?
domain is a pipe with diameter of 260mm and lenght of 4 m.particles are sprayed into the pipe.
no i do not see incomplete tracks.
trajectories in steady injection should be arranged and regular or Irregular and disordered?
are these trajectories acceptable?
the main flow is air and droplets are water.
i have another question.What are good values for step length factor and length scale?
how they should be selected for a simulation?
