Transient model pattern changing point
Hi everyone,
I found something interesting in my simulation pattern:
As I use an element size >=6e-5 and < 6e-5, the simulation patterns were completely different:
However, within their own group, simulation patterns were the same:
element size 5.5e-6 vs 5.75e-6
I am using the same original fluent file and only changing the mesh quality to export, all the settings should be the same. So I wonder if that's a problem associated with the mesh quality such as mesh orthogonality? would a change in bias factor in y-direction cause this issue?
cells with orthogonality>0.75 (element size 6e-6)
cells with orthogonality>0.75 (element size 5.75e-6)
the images of cells with skewness <0.8 and aspect ratio<=2 are the same with different element size.
Just wondering if anyone knows what could cause the difference in the simulation patterns?
Best regards,
Lugia_06
When you change your grid, do you also change your time-step to maintain the same CFL number?
Also, what are your VOF settings? Explicit formulation with sharp interface modeling?
What discretization schemes are you using?
Hi Kremella,
Good to see you on the forum again!😀 I kept the same number of time step and step size(1e-6) as I run the models, however, sometimes the fluent system itself auto changed my step size into a lower number like 9.999998e-7 (not sure if that matters).
Please see below my VOF settings and discretisation schemes:
explicit with sharp interface modelling
Best regards,
Lugia_06
no it doesn't matter ... I always have this issue 😁
