Adhesive melting — Ansys Learning Forum
Adhesive melting
michutorresmichutorres Member Posts: 60
Hi all,
I have two questions about adhesive melting simulation in Ansys Fluent:
1) When introducing the properties of a fluid in Ansys Fluent, what is the Pure Solvent Melting Heat (j/kg) ?
2) Starting from environmental conditions, would it be possible to simulate a heat flow input until a point or surface reach 150ºC and then remove the heat flow input and keep the temperature (150ºC) constant? Where can I establish this?
Thank you
