The web server reported a gateway time-out error. — Ansys Learning Forum
AndyJPAndyJP Member Posts: 221
Draft Not Found
Gateway time-out
   Ray ID: ###
   Your IP address: ###.###.###.###
   Error reference number: 504
   Cloudflare Location: ###
What happened?
The initial connection between Cloudflare's network and Vanilla timed out. As a result, the web page can not be displayed.
What can I do to resolve this?
Please try again in a few minutes. If the problem persists, you can contact the site owner to let them know you were unable to reach the website.
Your IP: 202.###.###.###
Ray ID: ###
Help Performance & Security by Vanilla Forums Inc.
  • RobRob UKForum Coordinator Posts: 8,851
    Thanks @AndyJP There's a 3(?) hour timer if you don't access the system that will time out for security reasons but there was also some sort of glitch overnight that meant I had to reload this morning after trying to access the Forum. Can you try again when you're on the system and confirm you can comment on here?
