Stator slot and rotor pole number
HaydarEzzedineHaydarEzzedine Member Posts: 3
A recurring error is rising while working on ANSYS electronics RMxprt. It says: "Stator slot number does not match pole number". I would like to know the reason why it doesn't match and when exactly does this error happen. Is there a ratio that should be avoided between rotor pole and rotor slots?
I am working with 3 phase machine, permanent magnet synchronous generator.
  • nchodenchode Posts: 224Forum Coordinator
    edited March 30 Accepted Answer
    Hi @HaydarEzzedine,
    That not a possible slot-pole combination. Proper winding combination can't be achieved with that configuration.
    You can go for either 12 poles 18 slots or 12 pole 36 slots or maybe something that works.
    Navya
