Undercut Anchor Simulation under Tensile loading
Following are geometries of the problem, Let me explain the procedure step by step so it will be easy to figure out the problem and provide the exact solution.
The wbpz file is attached to the thread.
Bottom surface of the specimen is fixed and the load is applied to the top of the anchor rod.
Two reinforcement bars are provided transversely at a distance of 175mm each from the center of anchor rod. There are two nuts and washers at the bottom of the anchor rod.
Can someone please help me with the simulation?
My heartfelt gratitude for your assistance in advance.
Above
Duplicate of https://forum.ansys.com/discussion/comment/110140#Comment_110140.
