NOTICE: We will be performing backend maintenance of our Learning Forum from April 5 to April 12, 2021. The result will be a new infrastructure but with little impact to user experience and design.
Currently the forum is accessible in read-only mode as we complete our final migration. Thank you for your patience.
For urgent issues please visit HERE.
Droplet Impact on Structured surfaces UDF — Ansys Learning Forum
Dear Ansys Community, hope you shall be in good health. i need help because i am facing some problem regarding droplet impact on the structured surface.
i am doing a 3D simulation for analysis of droplet spreading behavior on the structured surface.
i have written the udf is attached in the pictures.
To get spreading behavior/spreading factor/liquid-air interface the
"C_CENTROID(e,c0,t0);
r[i]=e[0]; "
is used in the udf.
1) the problem i am facing right now when the droplet hits the structured surface the fluent crashes every time.
2) if I remove that command mentioned above in the udf the fluent runs perfectly.
can you help me to fix this issue?
I need to use this command to get the spreading factor of the droplet impact.
i also attached the udf pictures and geometry pictures in the form pictures.
please reply urgently.
i have a due date of the project in my University.
It is actually the large droplet that is spreading gently on the structured surface with 0.1m/s velocity (low weber number), I tried taking F_Centroid but the in that case also ansys fluent is crashing.
It is actually the large droplet that is spreading gently on the structured surface with 0.1m/s velocity (low weber number), I tried taking F_Centroid t
I'm good thanks, hope all is well with you. I've also verified your account to try and stop the filters eating all of your posts.
I'm not sure why you're getting the problems, but suspect you're trying to store data or do a calculation in the wrong form: not all data is available on F_ or C_ so you may have broken something. What I would suggest is having a look at the VOF to wall film models, that may mean you don't need a UDF.
I am getting 999999: mpt_accept: error: accept failed: No error
before it is getting crashed for each face loop all the cells having volume fraction interface will get stored in r[ND_ND] and then I am using for loop to get the maximum value stored in r array to get the spreading factor (i.e. maximum distance of cell having vof interface)
I have used VOF multiphase along with EWF activated with initial boundary conditions on the wall of impingement . I hve then initialized the solution and then went to EWF tab left the default and given water for film and surface tension coeff 0.072 and max thickness to 5mm and then clicked on initialize tab on EWF tab. But i am getting maxcfl 0 even after droplet impinged on wall
ND_ND is 2 dimensions for 2D simulations and 3 dimension for 3 D simulation. so, with the fourth value you get "sigsegv". Declare r with a dimension larger than what you expect ... and initialise it with zeros, so when you get the maximum, you get an actual maximum
The question is here
r[i]=e[0]; "
is used in the udf.
Are you looking at DPM droplets or small amounts of VOF?
There are the wall film models, and if you're wanting the surfaces you need to look at a surface thread (F...) rather than the cell thread (C...).
It is actually the large droplet that is spreading, I tried taking F_CENTROID also in that case also fluent is crashing
it is droplet is gently hitting the surface with 0.1 m/s. In the case of taking F_Centroid also it is crashing
Thanks rob on coming my post..
its a long time not in touch with you hope you are fine.
stay safe
Usama
what is r and why it's defined [ND_ND]?
Do you receive "sigsegv"
add this before the two lines ...
Hi Selima,
HI Rob,
There's a transition depth so it the VOF level is high enough we resolve the film, as the depth decreases we switch to the film models.
