How can calculate a stress along centre line of single lap adhesive bonded joint of rectangular 3D s
pateldineshkumapateldineshkuma Member Posts: 1
I am working on ansys 17.2 apdl
  • sharveysharvey San Diego, CAPosts: 90Member
    Hello @pateldineshkuma,
    To do this interactively you can use the Path Operations in General Postproc. See image below. You will use the define path to set the path by nodes or location, then the Map onto path to set the quantity to the path, and finally use Plot path items to make contour or graph.
    The commands for these 3 main operations are
    path
    pdef
    plpath
    Let us know if this helps. Thank you
    Sean
