Script Error Ansys 2019R3
Hello.
I have a problem in Ansys Workbench 2019R3 when I use the Export To Excel function for analisys results.
I get the error
Even if i click Yes, it does not work, the excel is empty.
I reinstalled Ansys, Excel but it did not help.
Any suggestions?
Thanks.
@Ionutz83 Can you please post the picture of the errors you receive? I apologize, but we are not permitted to open attached file.
Many Thanks,
Geo
I enabled active X controls in IE, disabled third party browsers but nothing seems to help.
last year it worked fine, but when we tried to use this function this year, this error appears and it does nothing.
The problem is not related to one machine, I tried on 3 different laptops and the result is the same error.
The configuration is:
The problem is also present on a machine with Windows 7 so I don't think the OS is the problem, because it worked on both OS last year.
