Deadlock in MPI communication for this job
sridharsahoo366@iitkgp.ac.insridharsahoo366@iitkgp.ac.in India Member Posts: 4
I am simulating an internal combustion engine using ansys Forte. The simulation starts from 5° CA before the intake valve opening to 5° CA after the exhaust valve opening. However, when the intake valve open crank angle reaches, the deadlock in MPI communication for the job occurs. Thereafter simulation stops at that crank angle.
I am unable to understand the possible reason for this error.
  • RKRK Posts: 442Ansys Employee
    This error usually ocurs when you are running on fewer cores. Please use larger number of cores and try again. Let us know if the issue persists.
  • I am running my simulation in an HPC server, where I am using 80 core on 2 nodes. Please suggest how
    to resolve this issue
    I guess the issue cause due to the mesh problem at the intake valve opening. Sometimes, I get different errors at this crank angle like below.
    Error in creating auto mesh
    Assertion failed: RegionController.cpp:330
    CGNS solution file closed successfully
