System Coupling in Linux HPC ( Cluster type SLURM)
I'm working on FSI, I tried some tutorials of the Oscillating Plate with the command line ( CLI ) in the windows machine and it works properly.
the tutorial is here: https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v202/en/sysc_tut/sysc_tut_oscplate_cli_fluent_steps.html
When I wanted to use the same tutorials in the Linux HPC (type SLURM), after finishing all the commands properly, the last command to run the solving process ( Solve() ) gives me the following error:
Caught exception in ApplicationContext.mapModules
Traceback (most recent call last):
File "PyLib/kernel/framework/ApplicationContext.py", line 152, in __call__
File "PyLib/kernel/framework/ApplicationContext.py", line 61, in _makeComponent
File "PyLib/kernel/framework/ApplicationContext.py", line 59, in <lambda>
File "PyLib/kernel/framework/Annotate.py", line 50, in injected
File "PyLib/kernel/remote/service/__init__.py", line 280, in __init__
File "PyLib/kernel/remote/service/__init__.py", line 234, in _load
File "PyLib/kernel/remote/service/__init__.py", line 146, in _initializeComputeNodes
File "PyLib/kernel/remote/service/__init__.py", line 77, in _makeMultiportArgs
File "PyLib/kernel/remote/service/__init__.py", line 34, in getParallelOptions
File "PyLib/cosimulation/partitioning/machinelist.py", line 66, in loadMachines
File "PyLib/cosimulation/partitioning/machinelist.py", line 252, in _constructMachineListSLURM
TypeError: int() argument must be a string, a bytes-like object or a number, not 'NoneType'
File "PyLib/main/Controller.py", line 147, in <module>
File "PyLib/main/Controller.py", line 143, in _run
File "PyLib/main/Controller.py", line 92, in _executeScript
File "PyLib/kernel/commands/__init__.py", line 31, in readScriptFile
File "PyLib/kernel/commands/CommandManager.py", line 169, in readScriptFile
File "run.py", line 39, in <module>
Solve()
File "PyLib/kernel/commands/CommandDefinition.py", line 74, in func
File "PyLib/kernel/commands/__init__.py", line 28, in executeCommand
File "PyLib/kernel/commands/CommandManager.py", line 122, in executeCommand
File "PyLib/cosimulation/externalinterface/core/solver.py", line 125, in execute
File "PyLib/kernel/framework/ApplicationContext.py", line 30, in __getattr__
File "PyLib/kernel/framework/ApplicationContext.py", line 50, in __madeComponent
File "PyLib/cosimulation/solver/__init__.py", line 70, in __init__
File "PyLib/kernel/fluxdb/FluxDB.py", line 336, in FluxDB
File "PyLib/kernel/remote/RemoteObjects.py", line 202, in __init__
File "PyLib/kernel/remote/RemoteObjects.py", line 88, in __init__
File "PyLib/ComputeNodeCommand.py", line 81, in newfunc
File "PyLib/kernel/remote/RemoteStatus.py", line 18, in forceRemoteStart
File "PyLib/kernel/framework/ApplicationContext.py", line 157, in __call__
Please see these other discussions for how to launch System Coupling with a job scheduler.
https://forum.ansys.com/discussion/comment/106498#Comment_106498
Steve
