NOTICE: We will be performing backend maintenance of our Learning Forum from April 5 to April 12, 2021. The result will be a new infrastructure but with little impact to user experience and design.
Currently the forum is accessible in read-only mode as we complete our final migration. Thank you for your patience.
For urgent issues please visit HERE.
how can i build a electric source change with time like the picture bellow in INTERCONNECT ? — Ansys Learning Forum
You can combine several step sources with the delay options in it to form this waveform. For example, in the first step source, set its delay = 1e-9s, bias = 0, amplitude = 1; then in the second step source, set its delay = 2e-9s, bias = 1, amplitude = 1, so on and so forth. Then use a SUM element to combine the sources together.
Hi Xiaoran,
